jason.yergler
- Sep 23, 2017
- 10
- 12
- 2022
- 5.7 Hemi
My left trailer tail light doesn't work as a marker light or turn signal. Hazards and brake lights work. It doesn't work only when the left light is the only one functioning. I'm assuming the most likely issue is a fuse, but I couldn't figure out which fuse is the faulty one. Is there a dedicated fuse for those functions. I guess the next most likely issue is in the 7 pin connector or a faulty ground. Is this a common problem? Is it a fuse or am I going to have to follow that wire?
I haven't used a multimeter or test light to see if power is coming from the 7 pin, but it is the same with both of my trailers, including the new one I bought today, so I know the fault is in the truck. Thanks.
