Leveled out but want to keep it when...
Bigboy16
5.7l hemi
Ok ..lovin the Bilstein levelig kit..2.1 was perfect got the rears as well. seeing as I will be traveling west towing a packed 6x12 uhaul Id like to avoid alot of sag..leveled out the nosedown when towing before the kit. SUMO stops ..a different coil.??...no airbags or spacers wanted. 650 # of dualsport MC and gear for 3 months of trekking after the trailer. Just trying to keep it real simple. Thank you my brethren!
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
@Nick@GotExhaust is the go to for aftermarket parts. He can set you up with a set of rear springs that will handle additional weight
ram1500rsm
Trabuco Canyon, CA
I'll do Icon 1.5 springs. You get 1 1/4 lift, you'll lose about 1/2 lift with about 400-500lbs. You'll loose 1" of lift with about 800-1000lbs, feels stock unloaded and will allow you to run up to 27.5 extended rear shocks.
Nick@GotExhaust
Supporting Vendor
SC
There are a couple options out there. I do like the idea of the ICON coils. They ride really smooth. I prefer to go with a taller coil and let it sag a bit with a load rather than a stiffer one at stock height because the ride will start to suffer. The "tow" coils will start to make the truck ride like a 1 ton in the rear and you start to loose the smooth 1/2 ton ride.
Let me know if we can help, we can get you set up
