Leveling
Btimmy
Pennsylvania
I have a 2022 ram 1500 big horn. Will putting a 2.5 levwling kit hurt anything with the suspension?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Not if it’s done properly
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Where in PA are you?
IDSandman
Idaho
Don’t run pucks. Run the 5100 bils ride height struts. Zero issues if installed correctly.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
I’m taking it to an off road shop so I would think they would do it right.
You would hope.
For good measure and to remove any incompetent actions. We have preferred vendors on this forum. @Nick@GotExhaust is your go to for a pre built leveling kit. The Fox 2.0 coil over would be my recommendation as your off road shop just takes your struts out and puts them in. At the end of your lease if you decide not to buy the Fox coilovers will retain their value at resale.
Nick@GotExhaust
Supporting Vendor
SC
dont do level spacers. Do an adjustable strut or coil over. As @Quick_Shifter said if you lift/level your RAM correctly it wont hurt anything. Since its a lease I assume you do not plan to off road the truck. You got a couple options. On a lower cost option you can do Eibach struts and I recommend their coils as well. If you want an even more push ride than that you can can go with Fox 2.0 coil overs.
message me if interested and I can give you some quality options and we can discuss pricing.
FL-RAM
PENSACOLA, FL
2022 Bighorn Night Edition
V8
OP, sounds like you just want simple spacers. Tons of people have them and have no issues. Contrary to what some people say, they don't change ride quality and aren't going to hurt anything with the suspension. They are simple and inexpensive and can be easily removed once your lease is up. Maybe if you are planning some heavy-duty off-roading you might want full struts, but for 99% of daily driving spacers work just fine.
Goin Mobile
Pittsburgh PA
I recently installed the eibach adjustable shocks on my 2018 1500 Laramie. Reused the stock coils. I absolutely love the setup. Leveled perfectly and firmed up the handling without negatively impacting the ride. Did it myself including swapping coils. Not hard at all. Good luck. I’m gonna do the rear next.
B
Btimmy
Pennsylvania
What’s the biggest tire I can run once I level it. Thanks for your info.
FL-RAM
PENSACOLA, FL
V8
I have 33's on mine, but the general consensus is that with a level you can go up to 35.
Chap
Northern NY
2019 Powerwagon
hemi 6.4
Buy a Fox shock kit, when gas and food costs a fotune these days. OK.
Chap
Northern NY
2019 Powerwagon
hemi 6.4
Everything is so expensive now, so companies like Rough Country can sell their cheap, Chinese made crap on people.
FL-RAM
PENSACOLA, FL
V8
They also have a lot of people convinced that you need to swap out struts and control arms for a simple level. Motofab 2" level puck costs $40.
Bigs
Gatineau, QC
5.7L HEMI
I don't know if I'd spend that much on a truck that I don't own. Sure, if you plan to purchase at the end, but the 2 key words here are IF and PLAN.
But there seems to be mixed emotions on using pucks. What are the downsides of using pucks?
joshhhh
