lift upgrade
mudjunky
rusagonis new brunswick
Do any one have any experience takinga 4 inch rcx lift and making it into a 6 inch I was told my rcx and 4 wheel parts that you only need to replace a few parts aprox 300 dollar bill plus shipping for everything
just curious if any one has done it because from my research the cross member and many other parts from the 6 inch are the exact same as the 4 inch
Texas_Cornhusker
Hawaii
dos any one have any experience takinga 4 inch rcx lift and making it into a 6 inch I was told my rcx and 4 wheel parts that you only need to replace a few parts aprox 300 dollar bill plus shipping for everything
Your best bet is to call/email RCX and ask, they can tell you exactly what part# you'll need to upgrade.
White Beauty
Moncton, NB
2011 Ram 1500 SLT
add a leveling kit and a rear spacer?? then a 3 inch body lift and make it a beast!
Rock$tar
Newfoundland, Canada
Cummins 6.7L
The only real difference in the 6 inch kit and 4 inch kit in the front are your 2 front spindles and the spacer on top of the strut assmbly.
In the rear depends on the RCX kit you have. If you have fixed upper control arms, you need new ones, if you have the adjustable ones they just need to be adjusted. The rear springs also need to be changed in the rear.
mudjunky
mudjunky
I kinda like white beautyidee of adding a leveling kit but not shure im a fan of putting spacer bolt to a spacer bolted to strut assembly but I guess could always try it and if its **** sell it to one of my ram buddy but for the average price of a leveling kit for and extra couple hundred I can have all ruff country parts and not void either the ruff country warrenty or the dodge gotta wait to do all this any way Moncton Chrysler super store is buying me a new set of tires cuz they failed to properly align the truck after there lift kit specialise installed the rcx kit and it chewed 10/32 of my tires since I got the truck with is only 9000 km ago
Cruizer
Ohio
2010 Sport 4x4 QC
This is the route I'm looking to go. Bilstein 5100's up front with 1" spacer in the rear, then 3" BL. Moving up to 35" wheels and black rims. I have to get through Christmas before I can start this though. Can't wait!
Thor09
Northern PA
I wouldn't stack spacers. Do what Cruizer said, use a set of Bilstein 5100s to raise the front and then compensate the rear with a set of coil spacers, depending on the rake you want to have.
Wandell
Cummins 6.7
I agree.
Cruizer
Ohio
2010 Sport 4x4 QC
Anyone run at 2.8 with a 1.5" rear spacer? I'd like to see how that looks. I'd like to keep some rake and prevent squatting when hauling anything in the bed or a light trailer.
Cruizer
Ohio
2010 Sport 4x4 QC
I wish I could afford a 6" lift. Did you install it all at the same time or was there anytime you had only the Bilstein and rear spacer on?
Thor09
Northern PA
No unfortunately. I had the bilsteins maxed, then installed the 6" lift with 3/4" rear spacers. I was too high in the front so I removed the 3/4" spacers and put in 1.5".
Cruizer
Ohio
2010 Sport 4x4 QC
I was thinking 1" but now I'm considering 1.5" or 1.75". I'm going to install a 3" BL around the same time. Also going up to a 35" tire. Can't wait to get it done though, I have lift my truck fever now, lol.
Texas_Cornhusker
Hawaii
Just a matter if time before your on the side of the street with a cardboard sign saying will work for truck parts.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Cruizer
Ohio
2010 Sport 4x4 QC
I'd do it to if someone had a 6" RCX lift for me, lol. :laughing1:
Now I'm considering holding off on new rims and the BL and going for the 6" RCX with Bisteins and rear spacer. :emotions122:
mudjunky
mudjunky
I think im gonna get the parts for the front and rear to get it to a 6 inch but ad some spacers in the back and do a set of adjustable shocks up front at max set that should be almost 9 inchs technicaly then do a 3 inch body lift then il be happy with my short man syndrome hahahahaha
so if any one was curious heres the part numbers you need to turn you 4 inch into a 6 inch for 300 bucks
part 1329 box 3
and part 2322 which are some rear coils
my parts order list which will be getting done next month will be
pa 3 inch bl
part 1329 box 3 (rear track bar braket ,front spacers,lower rear control arms)
part 2322 (rear coils)
bilstein 5100 shocks
2.5 inch spacers out back
1.5 wheel spacers
mudjunky
mudjunky
I wonder how long of a shock im gonna need for that back any sugestions
also I may do suspension first and se how crazy high it is before I venture 3 inch higher and make the truck imposible to get in being 5 foot 6 hahahaha
mattman_13
Yea I can't buy skinny jeans now just so can maintain my ability to swing my leg high enough to get in mine.
La ratilla
