djbdmb041893
I have a 2003 1500 SLT, 4.7 auto. To begin I installed a remanufactured (FRASER) motor, pretty much everything new (fuel injectors, coil packs, plugs, TPS and much more). I had the torque converter bolts loosen on me (had a 46re) so I put a 545rfe in to what came stock. was sold a bad trans as it wouldn't shift and in limp mode. replaced that, and kept getting p0208 code, replaced injectors, also found a vacuum leak. trouble codes gone but still not responding as it should when accelerating. has anyone else had similar problems, any fixes found? ideas of things I can check that might solve my problem . again she's not posting any codes to give a lead of where to look at. Thank you for any input. Doug
