- Jan 1, 2023
- 488
- 768
- Location
- Quakertown, PA
- 2017
- Hemi 5.7
Figured I'd ask here since someone may have some insight. I recently changed my front sway bar and end links on my 2017 Ram 1500 5.7 hemi with 74,000 miles. Noticed when I pull into work, slow right full lock turn that there's a noise coming from the right side. Not loud,but because of the recent work I have been trying to listen for any issues. Sounds like a rubbing or slight groan, no popping. Did notice when I pull into my driveway turn around I go almost full lock left and there's no noise,but there's a vibration through the dash. Again, not bad,but noticeable when you're looking for things. I can go lock to lock when stopped with no noises. Crawled under the truck and everything looks fine, no ripped boots, no play in control arms, cv axle, end links, etc. Tried swaying side to side at low speed to see if it was the sway bar and or end links and can't make it reproduce the sound and no other issue. May have been doing this before the sway bar and end links, but I've been lowering the radio and put windows down listening for sounds. Any help is appreciated.
