my ram trucks
Morbidking
farmington pa
2015 big horn 2014 laramie
2013 ram big horns
prairie went back under lemon law
the blue one lease was up
M
Morbidking
farmington pa
the wife's prairie replacement 2014 Laramie its ready to go back under lemon law also keeps leaking water from drivers grab handle started at 500 miles ben back to dealer 6 times in one year and they cant find the leak I don't want to give this truck up as it has everything I wanted
M
Morbidking
farmington pa
the blues replacement after lease was up 2015 big horn 3 days old so far
jadocs
They take it off to re-seal around the roof under the headliner., then put it back on. I had the same leak, but it was fixed on the first try. Apparently this issue is fairly common.
M
Morbidking
farmington pa
Did they replace the grab handle or did they just take it off and put it back on?
not sure what they did every time I took it in they told me it was fixed took it in last Tuesday waited at dealer all day 5 miles from dealer it started leaking again wife took it in the next day told her when she picked it up a drain hose come off from sun roof hasn't rained yet to see if they fixed it my wife said this is the last time if it leaks its getting lemon lawed
vidor texas
magnum 5.2
You could always use a water hose or something and get someone in the cab to see if it is still leaking. I would take it in if it does and file it under lemon law because that is ridiculous. But I don't have good luck so if I did it it wouldn't leak with the water hose but would leak when it rained.
