PowrRam
- May 12, 2018
- 767
- 625
- Location
- Minneapolis
- 2018 Big Horn
- 3.6L V6
Give us a report. Maybe some pics.Thanks again...doing this tonight!
TXCOMT
Like Ramm5.7 said, clean the bolts that stick thru (my '16 has 2, not sure about an '11). Use some penetrating oil for a couple of days, get a wire brush up there and clean the threads best you can, and then the longest handle ratchet wrench you have (use a pipe if you have to on the handle) to get the most leverage you can- you'll need it.I can’t even get the bolts that hold my rear seat down out to do this mod
another thought... the right threaded die from a tap and die set on the end of the bolts will clean a lot of the threads up. I didn't have one the right size, or I would have done that.I can’t even get the bolts that hold my rear seat down out to do this mod
