Need help locating engine ground straps – 2009 Ram 1500 4.7L with 2012 engine
jjts
WA
Hi guys, I’m trying to track down some electrical issues on my 2009 Ram 1500 4.7L. The truck has a 2012 4.7L engine installed, but it is still using the 2009 engine harness.
Right now I’m trying to physically locate all of the engine/block/head ground straps.
So far I found:
One ground near the oil dipstick area
Two grounds on the lower driver side/front-middle area
On the passenger side rear of the engine, I found two braided ground straps coming from the same area
One of those goes to the body/firewall near the PCM
The other disappears toward the intake/rear of the engine and I can’t see where it attaches
One of the original braided straps was broken and had been repaired with 12/14 AWG wire, which I’m planning to replace with a heavier ground cable
I’m specifically trying to figure out: Where exactly do the factory ground straps attach to the block or cylinder heads on a 2009–2012 4.7L?
If anyone has pictures, diagrams, or can describe the physical location like “behind the passenger head,” “above the starter,” “near the transmission bellhousing,” etc., that would help a lot.
I’m trying to avoid removing the intake manifold unless I absolutely have to.
Thanks in advance.
J
jjts
WA
yeah I'm trying to avoid the intake but thank you for your time and response.
There's a neg (-) stud behind the battery,just build yourself some new ground straps to run from it. 1 to the engine block and 1 to the frame should help. Normal battery cables with the ends already crimped on work good as ground straps.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Invest in the big 3 upgrade. You'll be miles ahead. I've done both my rams, ended up doing my jeep wrangler, that's a big 7 upgrade. I've used 0 welding cable on thevrams and on the jeep #2 cable. All have really improved my electrical performance
nhansense68
