Need help with CV joint angle after leveling
mf20041500
U.S
Installed new torsion keys and leveled truck 2-2.5” in front.
Are CV angles to steep? Or should I be fine?
Any body have picture of ideal cv angle after leveling?
Waiting on new shocks so just wanna know if I should bring back down some to avoid issues while I wait.
jws123
nj
To me from the pics it does look a little on the steep side does it viberate or anything? Ya might wear them out faster common issue when people lift vehicles for example every couple years i gotta do upper balljoints on my jeep because of the lift.
crazykid1994
It looks a bit steep and l can imagine it’ll get excessive wear from the angle. You want the cv angle as close to flat as possible. My truck is a 2017 so not the same but this is just a point of reference. First picture is cv angle with leveling kit. The second picture is max cv angle my truck will ever see with the front lifted off the ground.
M
mf20041500
U.S
Not sure on vibration, wasn’t planning on driving it till I take it for alignment and get everything in a decent place first.
Any idea if I can get front differential drop brackets for 2002-05 1500?
Only ones I can find drop kit brackets is for 06-08, any chance they would still fit?
Th0mas
Ontario
Where can I get a transfer case drop kit for 2014 ram 1500 I'm having cv angel issues I have trackmotive extended cv axles but my angels are still way off and when I hit small bumps my axles are rattling I have 3 inch lift any other options would be greatly appreciated
DILLIGAF
Canadian Forces
Canada
Thats horrible.
sublime2300
