new exhaust...now the truck leans?
sickboy
So, had a FM muffler installed yesterday. Apparently, the stock muffler is super heavy compared to the FM and now my truck is 3/8 of an inch higher on the passenger side due the huge weight difference in mufflers. Anybody else notice this?
MADDOG
Living in a Firepit
6.4L HEMI
The difference between the two can't be more than 50 pounds and that doesn't equate to that much suspension compression, IMHO.
What's on the opposite side of the frame from the muffler location?
S
sickboy
there are no other weight changing mods on the truck. its only 2 months old.
R.L.K.
Bristol , Tn.
The stock muffler might weigh 40 lbs total .... I just replaced mine last week myself ... probably closer to 35 lbs imo
Your lean is likely from fuel level in the tank.
Gas weighs approximately 6.5 lbs per gal . The tank is on the left side at about the same location as the muffler .
If you have a 26 gal tank like me .a full tank weighs about 180 lbs and you probably just lost about 25 lbs with the muffler removal & FM install so at a full tank you now weigh about 205 lbs more on the L/H side .
Hope this helps !
Markcuda
Eau Claire Wisconsin
2026 Longhorn 4x4,short bed,22s,H.O twin turbos.
3.0 I6 H.O. Twin turbos.
I got the 32 gallon tank option, when full, my passengers have a hard time opining their doors cause of the lean)))))))
craigsez
Novascotia,Canada
gas
Hope this helps !
3.8 liters is 1 usa gallon = 6.1 lbs not 6.5 lbs
R.L.K.
Bristol , Tn.
LOL too funny
S
sickboy
Lol. Leaning because of a muffler swap? Awesome.
What the F would happen if a fat chick got in your truck? *****
pffft, no fat chicks in this guys truck!!!
R.L.K.
Bristol , Tn.
Can you please post this?
Markcuda
Thank you very much.
I did learn some thing today.
R.L.K.
Bristol , Tn.
I know right , it 3/8 of an inch LOL
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Haha body lean from a muffler swap.... not at all possible.
Let's not even get into discussion about winter fuel grades with much higher oxygen levels... I bet that weighs less than summer gas right!? Lol jk
Honestly who ever did the muffler swap prob put the truck on a lift or jacked it up. Once you yank the wheels off the ground the suspension is unloaded and needs some time to resettle.
