New Tires?
wader999
I have a 2009 crew cab slt, 4.7 engine. I have the 17" wheels. I need to replace my tires. i want A/T, but a little bigger than the ones on there now. Has anyone gone with a bigger tire? How big? I do not want a rub, I put larger ones on my Bronco II in the days and loved them.
thanks,
Wade
Georgia Dodge Boy
Stone Mountain, GA
4.7L
Might try askin over in the 4th gen section. However I believe on 3rd gen you can run 35's with a level no problem, maybe a few without. Dunno if it transfers over like this to the 4th though. Best of luck!
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
2wd or 4wd would matter too.
I run a 285/70/17, roughly a 33" tire. Kelly Safari Trex.
Its on an 01 but this well help in determining the look you want for meat of the tire
AV8B6015
6.7 CTD
I'm sure you can go a little bigger, just not sure how much. The stock tires on my 4x4 were just about 33's.
quietpeen
2021 TRX
Hellcat
did you decide on anything?
quietpeen
2021 TRX
Hellcat
durango4819
DE
4.7 V8
285/70/17 Nitto Terra Grapplers A/T on the rims you had. I have the same truck just a quad cab instead of crew. same specs as wermbangs tires. the pic is with my leveling kit but they fit on there before just fine without rubbing.
Lowrider357
