New to Rams
Glyn ellis
England
i have just purchased my first ram. ( I posted in newbie section) it is a 5.9 v8 on lpg 2002 Ram 1500
A member in newbie section suggested that the fluids may be special ones. Seen as tho when I collect it I will want to check/ change the fluids for my own piece of mind can anyone suggest what I should be using. The truck has done 128000 miles
desync0
Ontario, Canada
2019 Classic
I had an 02 with a 360, not sure what your friend means by special fluids.
Other than the factory LSD if you have it, doesn't like synthetic gear oil. Use conventional and add the friction modifier.
Oh if you change plugs and wires pay attention to wire routing, there's a tab with a diagram. Some trucks will get a random misfire if you don't do that routing in a tsb.
Sent from my SM-A505W using Tapatalk
tidefan1967
Summerville, South Carolina
Welcome! Special because of the LPG? The only thing that's really different is that your engine oil will stay clean for a lot longer since LPG is so much cleaner burning that gasoline. What's the price of LPG there vs gas/petrol? Is t that much cheaper?
Glyn ellis
Glyn ellis
England
Lpg is around 0.61pence per litre where as petrol is around the 127 pence per litre mark
joshhhh
