New wheels and tires.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Not usually much for lowering, but this looks mighty fine.
TylerB
TylerB
FL
how low is your truck? it looks pretty low
My current truck is Belltech 2/4 with a coil cut off the rear springs. I'll probably be lowering it another 1" all around to get rid of some of the fender gap some time soon.
The silver 02 was like 5/8 in that pic. It rode like **** so I bumped it back up to 4/6 and it was much better..
SILVER_BULLET
so right now its at a 2/5 or around there? and do you think you have enough clearance between the rear end and the frame to go that extra inch all around?
TylerB
TylerB
FL
Yeah, just gotta cut the stock bump stop cups off.
SILVER_BULLET
cool i want to see how it comes out mine is lowered on stock coils just cut but im going to be the belltech kit and try to go as low as possible without having to c notch it
spymac
2011 Express
Hemi 5.7 - 390HP
Hey Tyler, how has the combination of 4.10's and 285/50's affected your highway MPG/ driveability? I'm looking to get a setup very similar to yours. Thoughts?
TylerB
TylerB
FL
It's hard to tell the actual MPG loss from the tire height difference because I got a tuner just before mounting the wheels. I would say I lost more MPG because of the tuner. The gear swap and tire swap has totally changed the feel of the truck compared to the stock 3.55s and 33" tires. The tire swap felt like I did another gear swap on top of the 4.10s. It is soo much more fun to drive now, it's hard to keep my foot out of it and it breaks the tire loose so easily that I found myself drifting A LOT!! That has the biggest effect on my MPG, but I'm still averaging 15 MPG so what the hell. Definitely worth it. I can't wait for my 3200 stall converter!
09SMOKINHEMI
TEXAS
Heck yea!!!! Did you get an edge?
sent from my Samsung Galaxy S3
TylerB
TylerB
FL
I haven't ordered it yet, I'm waiting on my tax return. I'll be going with Circle-D.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
To Op, That is one of the nicest 4th Gen Street set-ups I've seen, well done and the Diff cover is a nice Touch too. Even this Ol fellow admits that Lowered is Cool.
09SMOKINHEMI
TEXAS
Yea that differential cover is nice. I'm thinking of doing that too when I save up for my gear setup
TylerB
TylerB
FL
Just be aware that if you are lowered that you will have to do some cutting for a larger differential cover to fit on the 4th Gen trucks. There's a weird, pointless piece that dips down under the bed that will hit the larger cover. I'll post a picture a little later.
TylerB
TylerB
FL
Ok, the red shows what I cut approximately. It's not pretty, but like I said the part I cut serves no purpose.
I just wanted to show with these two pictures that while it is tight, there is still plenty of room with the factory sway bar and track bar.
You can also see my cut and rewelded, shortened anti-sway bar tie rods.
09SMOKINHEMI
TEXAS
wow interesting.... i didn't know you had to cut pieces for the cover to fit. good to know. thanks for posting the pics
TylerB
TylerB
FL
No problem. Two minutes with a sawzall made quick work of the problem area.
Cowboy345
Kentucky
Nice ride, how about some more info on that rear diff cover?
TylerB
TylerB
FL
What more do you wanna know? The Mag-Hytec differential costs about $255, I got it from Moes Performance, it holds 1.25 more quarts over stock, has a magnetic dipstick, a magnetic drain plug so you can do routine lube maintenance without removing the cover, a fill port on the front, a port on the top for a optional temp sensor, a built in O-ring gasket that is reusable so no more messy RTV or leaking cork gaskets, comes with all new stainless hardware.
I think that's about it.
TylerB
TylerB
FL
I need to add new pics to this thread. I lowered the front another inch and the rear 1-3/4".
Kdog57
