No backup lights on 2003 1500
rspeer
4.7L
My 2003 1500 w/automatic transmission has lost power to the reverse lights. fuse is good, bulbs are good, any ideas what to check next??
R
rspeer
4.7L
The brake and turn signals are working fine and are from the same wiring harness so I don't think it's a bad ground. Someone said it was a backup switch, but this is an automatic so not sure where this switch would be mounted.
WilliamS
Tampa FL
reverse switch likely died. Check the grounds then replace the switch. I think on that model its on the driver side of the transmission.
R
rspeer
4.7L
On an automatic transmission? I knew there was on on a Manual Transmission but on an Automatic one as well? I read somewhere that it might be something called a transmission range sensor/tps assembly
alphaprojects
