sentrek
My sons 99 ram 1500 has led tailights in it and for some reason the brake light and the turn signal on the rear passenger side do not work. The brake light and turn signal on the driver side work fine. I pulled the light from the drivers side and plugged it into the passenger side and it was the same issue, No brake light and no turn signal but the running light works. The running lights, the brake lights and the turn signal are all the same set of leds. The flasher relay is led compatible. Any ideas where to start?
The reverse light on the passenger side is a typical bulb and it was burnt out so I replaced and it worked, but I also noticed the passenger side light for the license plate is also out. Everything on the front end works fine.
