No radio
woody31
texas
4.7 Special Service Vehicle
Hello ,,I have no radio when the key is in the accy position. Also the steering wheel does not lock when the key is removed. Not sure if the 2 issues are related. Anyone have a solution to this problem? Thanks in advance.
Core-Lokt
2005 Ram 2500 4X4 ST
5.7L
I have a guess, but I'd like to ask a couple of questions first. You're relatively new here, so I'm wondering how well you know the vehicle.
1) Are these issues new?
2) Is it something you just noticed?
I'm not entirely sure what an SSV is, exactly. I'm guessing some sort of fleet vehicle, possibly LE-related. Given that, I'm thinking this is a deliberate build configuration. I remember reading about some police car (want to say it was a Ford Crown Victoria) that had a feature of being able to start by twisting the "ears" of the ignition.
woody31
woody31
texas
SSV stands for Special Service Vehicle...
no power to radio in accy position
Core-Lokt
5.7L
Uh, let's try this again. I know what the abbreviation "SSV" means. I simply don't know what merits the appellation. And therein is possibly the answer. Never mind; I looked it up and it's some police truck, like I thought.
You never answered the questions about the problems. It's really necessary in order to figure out if something is broke or it was made that way.
woody31
woody31
texas
It never has worked in the accy position,,i alweays have to leave the key on to make it work
Core-Lokt
5.7L
Well, there are two possibilities.
1) It's a deliberate build profile for the application
2) Something is defective
The first thing I would do is remove the center dash panel and pull the radio. Next, detach the harness from the radio and test the connector pin-outs for power while the key is in ACC.
2003 Ram 1500 Radio Wiring
2003 Dodge Ram 1500 Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located Behind The Glove Box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Light Green/Red
Left Front Speaker Negative Wire (-): Light Green/Dark Green
Right Front Speaker Positive Wire (+): Light Blue/Violet
Right Front Speaker Negative Wire (-): Light Blue/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): White/Black
Right Rear Speaker Positive Wire (+): Tan/Violet
Right Rear Speaker Negative Wire (-): Tan/Black
Try that and see if the circuit is powered. If not, you'll have to find the Body Builder wiring schematic for your year and follow the wiring through the involved circuits. Or you may find that the wire is hot and the radio is bad.
woody31
woody31
texas
Thanks for the reply. The radio works, Just not in the accy position. Could it be a bad key switch? Steering wheel does not lock either. Thank you.
Core-Lokt
5.7L
If your ignition switch is supposed to lock-again, IDK if it is, given the nature of the configuration-then it wouldn't hurt to replace it for that reason alone. However, that might not have anything to do with the radio working in ACC so the affected circuitry still needs vetting.
This is an old police truck and surely had some custom wiring for accessories like lights or radios. It's really tough to say without knowing the history of the truck.
woody31
woody31
texas
Ok thanks,,I appreciate your time and replies. Have a great day.
justin13703
MD
Have you checked your fuses? There is usually a fuse for the accessory circuit on the older trucks.
woody31
woody31
texas
Thanks for the reply, Any idea which one it is? No owners manual to reference to.
Core-Lokt
5.7L
Open up your fuse box and look on the underside of the lid.
woody31
woody31
texas
Lol OK thanks
