Noob Question...
Ceace
Guys, how are you all lowering the rear to even with the front? Are you all still installing lowering kit, only for the rear?
Darkflow
Odessa, TX
Yea there's a McGaughys drop kit for 2" drop springs to level the rear with the front. Check out Moes Performance.
Sent from my SPH-L710 using Tapatalk
BlkRamRt
SoCal
HEMI 5.7
I agree with darkflow....but i would just go ahead and do the full 2/4 lowering kit you will not be dissapointed.
audio1der
Airdrie, Alberta
If you lower the rear, the front will follow a littlle bit. when I lowered our rear almost 3", the front lowered 5/8" as a result.
If you're going to tow anything significant you may want to keep an inch or so of rake, and invest in some helper airbags. Otherwise you'll be riding the bumpstops HARD while towing.
