Off Road Group - Air Suspension - need rear shocks
Mojo88
Rhode Island
'19 Longhorn Gen5 ORG
Hemi 5.7L non-eTorque
2019 5th Gen - Off Road Group - Air suspension - need a set of rear shocks.
I have the ORG (Off Road Group), which sits 1" higher than normal. Not sure if this utilizes same shock as non-ORG, anyone know??
ORG suspension is bone stock, no mods. One factory rear shock is leaking. I am just looking for acceptable shock absorbers, nothing crazy. What are you guys using??
Thanks
EDIT:
@AllMoparParts.com - Benny, can you possibly tell me which rear shocks I need?
RAM 1500, 2019 5th Gen, ORG, Air Suspension, VIN # 1C6SRFKT1KN567081
RamChief30
Phoenix, AZ
5.7L HEMI Gas
I just replaced my non-ORG 2019 Longhorn rear shocks with Bilstein B6 4600, but they probably won't work with the ORG because when I put the truck into OR2 to get the clearance to get the bottom of the shock into the slot, the shock was a tad short and I had to jack the rear axle up an inch or two. My bottle jack worked great for this. but, I think the extra inch that the ORG has would make it that the B6 4600 isn't the correct size for you.
Mojo88
Mojo88
Rhode Island
I wanted to follow up on this, in case someone else has this issue. The ORG option does indeed require it's own rear shock. I couldn't find an answer anywhere, even tried AI, but that gave me the WRONG answer. I emailed Benny's group, but they didn't answer very quickly.
So I went out and looked at the shock, wiped off the dirt, and right there was a big beautiful sticker that had all the numbers on it (copy below). Once I had that number - 68262593AC - I was all set! My new shocks should be delivered today.
Moral of the story: when in doubt, look for the part number on the part itself (if it's OEM).
