Off road rear light mounting options (under bumper) Power Wagon 2021
dmcoe720
Ohio
HI all, been searching a bit, looking for rear under bumper mounts for lights. Can't see at night with trailer/hunting. Any suggestions on where to source mounts? Thanks
jabartram
Corpus Christi, Texas
2020 Power Wagon
I mounted here
Airmousam
new Hampshire
Do you have the 75A or the tow pkg? Has the super bright rear facing LEDs in the mirror..assume you've tried those...I love em
Gregdad
Fort St. John BC, Canada
I have two side shooters under my bumper attached to my receiver with 2&3/4” muffler clamps. Works awesome
skydyver83
New York
Hemi 6.4L
These brackets or something similar give you a little more flexibility than the muffler clamps (I've tried both). They can be mounted at more locations on the bumper. Only issue I've found is that one loosened up on me, I guess from vibration after 1k or more miles. A set screw backed out but I found a replacement at Ace Hardware. More expensive than clamps but relatively in expensive. After some thought, if and when I do replace them I may go with something with more quality, after all most of us are hanging very expensive lights off them. I've also seen some members cut their bumpers to flush mount lights, very cool but beyond my skill level to do well.
Amazon link:
D
dmcoe720
Ohio
Thank you all. 75A edition. Gonna see if I'll mount to hitch. I'll report back. I figured this group would be the best to help me out.
Airmousam
new Hampshire
If it's 75A did you try the led lights in the mirrors? I used mine over the weekend..pretty powerful for what they are
Quigs1975
Chester County PA
2021 PW 75th Anniversary
I have the 75a edition however I’ve never noticed LED lights in the mirrors coming on when I back up. Am I missing this?
Airmousam
new Hampshire
They work in either park or reverse...button is either top or bottom in the center of the headlight knob...not automatic and you'll see why when you check em out...bright as hell
D
dmcoe720
Ohio
Ditto, I am not sure about the lights in the mirrors? is there a setting to get these to activate?
D
dmcoe720
Ohio
https://zroadz.com/i-23910124-ram-rear-bumper-led-kit-with-2-6-inch-led-straight-double-row-light-bars-pn-z384521-kit.html#!submodel=POWER WAGON||model=2500||make=RAM||year=2016
May have to call to confirm fit. They light the up night. I'm running on a 2016. Warranty is pretty good too, one of lamps had water entry and they replaced it with no issue. Could get damaged or torn off depending on off road conditions though.
Just confirmed this will fit the Power Wagon. Did you wire into a control module or just a switch. trying to figure out if I should buy module now or wait until I have more lights. Next year will add lights to boat trailer for night time backing.
JC4041
Rosamond, CA
I guess I got spoiled with my 09. While the 21 Laramie may have a better camera, it sucks at night. Maybe it's because the reverse lights are in the middle instead of the bottom like my 09. I've been eyeballing these so they won't hang down so far.
SeppW
Northern VA
Hemi 6.4L
I guess I foolishly did not not order the aux switches when I ordered the truck and was going with an aftermarket solution, but instead went the OE aux switch route which came with fuse/relay block hanging off a harness. Wired the power lead into block and grounded to chassis. IIRC, the kit comes with a harness that has a switch, so wire it up, mount the switch in the cab, and good to go. I would also advise you if plan to add more lighting and other assy, don't power off the battery directly, but use an aux controller or a secondary fuse/relay block for power and a central ground to chassis. Note amp requirements and use appropriate gauge wire, relays, and fuses. Never cut/splice/tap into the factory harness for power. Asking for problems in the long run and "could" void warranty.
Xyleff
California
Never knew… never really noticed lol
ROYSZZ4
