Pics of Leveled Quad Cab?
Want to Drive
Tampa, FL
I have a 2014 Quad Cab Sport 2WD. I'll be needing new tires soon and now would be the time to consider a level or small lift. I searched the forum for pictures, but a lot of the pictures I came across were crew cabs, 4WD, or taller lifts.
Would be awesome if anyone is willing to share pictures of their quad cab with level or small lift.
Cruze418
Rock Island
I'm going to lower my 2 wheel drive, but have to wait till the warranty is gone. Then air ride for the rear if towing. Gotta watch which lowering kit you use so that the geometry stays the same.
Rt71668
Long Island
Marshall
Sk, Canada
2014 sport
I have a '14 Quad. cab, but its stock, I kind wish it was lower.
The build sheet says "Raised Ride Height", what ever that is, block in back, longer springs?
As far as pictures, a quad cab or crew cab should look the same , the wheel base is the same , unless the crew cab has a special order box.
