moregrip
- Apr 19, 2015
- 614
- 222
- 2015
- Hemi 5.7
So I received my Belltech lowering springs recently and decided to do some measuring. Looks like they are 5.5" OD and about 13" long.
Based on research done by another member here(ty) they are rated from Belltech at 800lbs.
I've discussed with and researched spring rates(nothing I would call comprehensive mind you) with other truckers who autocross and they use spring rates that range from about 900lbs to 1000lbs understanding some weight reduction has taken place.
So I'm thinking for our trucks with street performance in mind a setup of about 1000lbs might be a good starting point.
If you look at this page Afco sells a nice 5.5" OD spring rated @ 900/1000/1100 lbs respectively and measuring 11" long. Obviously that is a bit short......
https://www.afcodynapro.com/store/b...lSprings-57?search_api_views_fulltext=&page=3
I was thinking, with this adjustable spring spacer in place I see no reason why the 11" springs wouldn't work in our application; one could then fine tune their individual front suspension ride height(assuming less spring compression once a vehicle weight is introduced).
https://www.afcodynapro.com/AFCO/550693851
thoughts?
thoughts?
