95360magnum
- May 31, 2013
- 53
- 1
- 1995
- 5.9 magnum
So just to start, i work at a salvage yard, and we just got a totaled 2006 charger in, that has the 5.7 with 68000 miles on it, i can buy the engine for $800, the shop guys damaged the oil pan pulling it, but i assume it would need a truck pan anyway for the swap, my question is, do you guys think i should use the trans in the car? Or build my stock trans? (If it will bolt up) it has ecu, engine harness, and all accessories, what will i need to convert to a cable throttle body? And would i be better off going standalone? Or run stock computer until it is time for boost?
sent from the interwebs powered by beer and gasoline
