The only true way to know if a truck is ideal for a particular trailer is to load both with everything normally carried including people and then go to scales for axle weights. Unfortunately, by then it is to late to do much beyond downsizing the trailer or getting more truck (doing nothing is not advisable). Seeing that trailer towing capacity is so misleading, they shouldn't even be able to list that because it is rare variant of the truck that comes even close. Like my 2500; it has 3k pounds of PC so theoretically it should be able to tow 20k pounds (20,000 x .15 = 3,000). But in reality, 3,000 less 500 pounds for people, less 40 for hitch, less 300 pounds fuel, less 100 running boards, 100 bed cover, leaves me about 2k actual payload capacity which translates to about 13,000 pounds maximum towing capacity.
Then trailer weights; those printed plates are worthless. With large volume of storage usually up front, full propane tanks and battery, the weight spread is usually disproportionately up front which crushes actual towing capacity. Trailers aren't built with proper weight distribution as the first concern, my experience is manufacturers don't care where it is.
