NOW AVAILABLE: 2019–2024 RAM 2500/3500 HD 12" Full Digital Speedometer EVIC Instrument Cluster
Infotainment.com
Supporting Vendor
Orlando, FL
2016 Ram 1500, 2019 Ram 2500
After tons of development (and a lot of requests from the community), it’s finally here! The OEM 12-inch Full Digital Instrument Cluster upgrade for 2019–2024 Ram Heavy Duty trucks. If you’ve ever wished your interior matched the premium feel of newer or higher-trim Rams, this is the upgrade you’ve been waiting for.
What This Upgrade Does​
This isn’t just a visual upgrade—it completely transforms your driving experience.
  • Massive 12" Full Digital Display
    Replace your analog cluster with a crisp, modern, fully digital screen.
  • OEM Ram Technology
    Pulled straight from high-end trims (normally found in $70K+ trucks).
  • Integrated Navigation Display
    View turn-by-turn directions right in your cluster (requires 2023+ radio module).
  • Customizable Interface
    Cycle through menus, vehicle data, and widgets using your steering wheel controls.
  • Plug-and-Play Design
    No dealer visit required—everything is designed to work seamlessly with your truck.
Smart Engineering (No Headaches)​
This kit includes everything needed to make the upgrade work properly:
  • Vehicle-specific plug-and-play harness
  • BCM communication integration (no module replacement required)
  • Security gateway bypass + OBD Genie programming for proper functionality
The system essentially allows your truck to communicate like a 2023 model—unlocking full compatibility with the digital cluster.
️ Installation Overview (Difficulty Rating 2/5)​
This is hands-down one of the most impactful OEM upgrades you can do to your Ram HD. It’s clean, factory-correct, and completely transforms how your truck feels behind the wheel. If you’ve been thinking about upgrading your interior—this is it.
Have Questions?
Our U.S.-based team is ready to assist:
Call: 1-855-636-6287
Email: [email protected]
Live Chat: available on our website during business hours
ram150082
