RealTruck, Gator FX Tonneau Cover
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Howdy 5th Gen world!
I just picked up a 2024 Laramie Night Edition with MFT. I’m looking at tonneau covers that will fit. Gator FX is on the list. My concern are these corners at the front of the bed. Anyone know if they’ll be an issue?
LugsLeadOut84
NYC Suburb
I've bought & installed 3 hard tri-fold and hard roll-up tonneau covers on 3 different trucks and they all had a knob-type screw to secure the cover at the front of the bed pretty much where those supports are. I can only suggest contacting Gator customer support, as the manufactures could tell you exactly where the knobs fall. Sorry for the answer that didn't tell you much...
Jrod
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
No worries, I have since bought and installed the cover. Everything worked out fine. The only issue I’m having now is missing drain cups… RealTruck is working the problem on their end to have the manufacturer send me the cups. Still waiting..
LugsLeadOut84
NYC Suburb
Ok. Just for future knowledge...the cover installed without issue with those corner braces?
Jrod
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Yes, the bed cover rails are cut to fit around and over the corners. The cover is configured with brackets to utilize the corners in order to lock it down on that end. You just need to make sure you do two things. First, make sure you select with MFT when ordering. Second, don't install the cover without making sure you have all your parts like I did... This will void the return policy with RealTruck.. Now I'm at their mercy waiting to receive the drain cups necessary to install the drain tubes under the corners.. It's been five days and still no shipment nor ETA for my missing parts..
kd70qc
U.S.
Hurricane SO
Added a bed rug and BakFlip MX4 to my ‘25 Quad Cab with multi-function tailgate
kd70qc
U.S.
Hurricane SO
It came with attachments to the corner L-brackets in the bed for the MFT.
I ended up trimming the bed rug around the L-brackets, and cutting the tailgate portion off. The remainder from the bed tucked nicely over the edge of the bed between the MFT hinge and bed.
A guy at one accessory shop said they didn’t make one for the 6’4” bed with the MFT. Another shop said sure and walked me over to the MX4.
phorrestphire
