Remote starter wont start
Davyd1
Pennsylvania
Hello I recently installed a new computer on my 2013. Ram1500 SLT prior to that, my remote starter, which is a Viper DS4 from Best Buy used to work. Now I can't get it to work. It goes through the motions the needles sweep The guages lights turn on, but the starter will not engage. I can lock an unlock the truck with the FOB that came with the remote starter so it's paired with the remote but it won't start. I tried to initiate it with Alpha OBD with no avail, the other option is to reset the RF hub or the PCM I'm not sure if it's reversible if something goes wrong. Has anyone ever experienced this or familiar with resetting the RF hub or PCM ?
Thanks in advance
David
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Did you change the VIN number in the PCM and do an RF hub reset before trying to start it? When I installed the unlocked PCM for my tuner, did all that stuff before trying to run the truck.
Now I can swap the locked / unlocked PCM's on mine at will and it all works OK, but I have OEM remote start.
D
Davyd1
Pennsylvania
Hello when I purchased the PCM online I gave them the VIN so that they could program it and make it plug and play. I had to cycle the ignition key so that the PCM shakes hands with the truck and it did it started right up, no issues it's been over a year. It just won't start with the remote starter. I read about the RF Hub reset I'm afraid if I do that it might not start, I don't want to screw anything up. I've never done that before I'm not sure what the outcome will be.
Thanks for reaching out I appreciate it
04fxdwgi
2016 1500 Sport
When I did the RF Hub reset on mine during a TIPM problem cure / configuration change, it also corrected some other problems at the same time, notably problems with it not seeing all the key fob functions all the time.
Did the reset with AlfaOBD. East Peasy.
D
Davyd1
Pennsylvania
View attachment 592105Hello again I reset the RF
Hello again I reset the RF HUB today with no avail, I do all the work on my vehicles I always have this one has me stumped as much as I don't want to I'm going to have to throw in the towel and take it back to Best buy.
Thanks for your help I appreciate you
DITRIO
