Replace factory strut components when installing Bilstein?
2k9ram
After a short stint with the Rancho Quicklift's I have elected to go back to Bilstein 5100's.
While I still have all my factory components, I am wondering if I should build my new Bilstein's with a new top plate. The last time I had Bilstein's installed and set at 2.1 I had a new unwanted front end noise at low speeds, and this time around I want to try and eliminate that!
I could never pinpoint what was causing the noise, and when I first installed the Bils I of course installed the washer in the wrong place. I did not drive the truck long (not even a full day) before switching it to the right position. But I fear even in that short time I could have done some damage to the top plate.
So my question for all of you! When should a guy replace the factory components when building out the Bilstein's? What brand replacement parts do you suggest one uses when they do? I see Monroe has a replacement top plate.
JB1
Houston, Texas
Good question
Does anyone have the OEM p/n's for the strut parts?
ivey_usmc
Austin ,TX
I have mine set at 2.8 and no noises and issues as of yet.
VB712
Maxi_built
Va Beach
What issues are you having with the ranchos that make you want to switch?
Maligator
Hem 5.7
The only addition I made was mevotech UCAs. I had a minor squeak but I think I underfilled my ball joint.
2k9ram
My only frustration with the Rancho Quicklift's is that I only get 1.25" of lift, despite their advertised 2. I had previsously had my Bils installed at 2.1 and loved the look, and I measured around 40" up front. With the Rancho's I am measuring around 39". The ride is great, the noise is gone, but the rake that still exists might as well be the factory one IMO.
Sunmerk
