Rf hub burnt need help with wiring and finding a connector
clay9876
Nc
First off I'm new here so bear with me.
Now let me give you the details.
i just picked up a 2013 HD 2500 it had a fire in the bed and it spread through the vent on the rear of the cab and burnt the rf hub and the wires going to it. I'm planning to buy a new rf hub but i haven't been able to find the connector I need or a wiring diagram for it.
So if someone could help find the connector and the appropriate diagram or give me a list of vehicles I could possibly get one from the local pick and pull
And will i be able to program the new rf hub using alfaobd and the obdlink sx (left over from programming keys for a 2012 ram) or do I need to buy something different
Current rf hub P/N : p68207773aa
Replacement rf hub P/N 68207773ab
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
This'll get you what you're looking for...
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
That's exactly what I needed thank you
No problem, I'm not sure as I've never done it, but I think you'll need an App like AlfaOBD to get a new RF hub up and running.
C
clay9876
Nc
yea I have AlfaOBD from when I replaced the win module in my 2012 3500 but I have to order the correct adapter for the 2013+ trucks
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Great, at least you won't need a Security Bypass Module cable for the 2013!
C
clay9876
Nc
Yep got the adapter and the rf hub and connector ordered should be here middle of next week then we will see if my gamble on this truck was worth it
mjfargo02
New york
Clay do you have a part number for that connector? Or where did you find it on that connector site..I looked around and not sure what to look under on there..any part # or info would be great, thanks!
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Is this what you are looking for?
mjfargo02
New york
C
clay9876
Nc
I believe that the harness for the rf hub is made into the cab/body harness. So I think you'd just about have to disassemble the whole inside of the cab or at very least a good chunk of it. That's why I'm going to try just replacing the burnt part of my harness first. Also I ordered the kit for the c1 connector in the picture sitkneelbend posted above.
snogle
For anyone finding this in the future, here is just the connector. That page also has a Ford part number that works if you need something fast. $20 and had my brother's truck back on the road.
