Ogahpah
I’m new here and I’m sorry, I know this has been discussed. But I think I’m close to the goal line and can cross over with a little help.
I have a 2014 Ram 1500 Laramie 5.7 8 speed trans. When I’m press the button everything lights up but it will not crank. I think it might be the RF Hub. This truck does not have remote start but is keyless.
I have a U1433-23 DTC that won’t clear. I have checked and scanned everything. Battery, grounds, wiring, fuses, etc. I ran a diagnostic flow and found I have low voltage (1.2 volts) in the run start output circuit between the RF Hub and the BCM. I’ve checked the pink/white wire in that circuit and it is not open or shorted.
I have noticed the fob appears to be functioning fine except for passive entry and auto lock.
Any help would be appreciated and again I apologize if this was already covered somewhere else
Brian
Brian
