Roof Rack with LED Lights for 09-18 Dodge Ram 1500
Hooke Road
Supporting Vendor
CA
Hemi 6.1
Top Roof Rack Cargo Carrier
Meet your cargo needs and night lighting needs.
Durable Steel Construction - This roof rack is built from heavy-duty steel to ensure maximum durability against heavy loads.
E-Coating Process—The bumpers can last for 100 hours during the salt spray test, equivalent to a 5-year corrosion capacity. The product pass percentage reaches 100% after the salt spray test.
Simple to Install. Assemble the structure of the luggage rack, and lift it to the roof. Minor drilling is needed to complete the installation. Need some basic hand tools and a drill. Assembly and mounting hardware are included. If your truck is quad cab, you must use some 1/2-inch spacers for proper clearance.
You should expect to take up to 2 hours to install this unit, based on your level of mechanical skills. Attempt to complete the operation in your garage and save you a pretty penny ranging from 100 to 500 dollars.
