deeray
2007 ram 1500 5.7 hemi w/mds. ok as im driving down the interstate at 75mph the rpm gauge will just drop to 0 and i lose all power. but the truck doesnt shut off. ill hit the throttle a cpl times and it comes back up. however on occasion while sitting at a stop light the engine will stall and shut off. in the past 3 months ive replaced o2 sensors, mds solenoids, crank position sensor, cam position sensor, egr valve, throttle body, ecm, oil pump and timing set (i replaced timing cause it was showing a spark advance of 34 deg. timing tensioner was completely ate thru by the chain.),all plugs and coil packs. it has thrown trouble codes for just about all these sensors. i replaced the ecm when it was telling me that the crank position hasnt been learned. yet my problem remains. currently getting random misfire codes. ive checked wiring harness for any broken or loose wires. im open to any ideas of what can be wrong. or if there is something i might have missed.
