Shorty antenna
stygz
I am looking for a shorty antenna form my 16 ram. Looking for a quality product that looks good and has a good fit. Something around 12" would be fine. Suggestions?
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
Plain ole shorty from Walmart fits great, good reception. $12
coldfusion73
Ontario, Canada
I had put a 13" on mine but the whistling at Highway speeds was horrible ended up putting original back on. Not sure how the other shorter ones are.
07MegaCabRam
Chandler, Arizona
6.7L CTD
I also did a thin metal one that was 4" - don't use the radio too often but in the mornings and but never had any reception issues.
Mine looks like someone just cut down a factory antenna. It doesn't have a bulky black plastic piece around it.
HolyRam
Cummins 6.7
Mine is 3" and black plastic. Reception is okay but it looks great. I usually use XM anyways
pkrider
6.7 diesel
I use the 4" shorter, far knowing that reception sucks!! I only listen to XM so that isn't the issue, I also like the fact I can put my truck cover on it with the shorty
nateinva
Central Virginia
5.7L
No whistling at highway speeds? What is the brand of the antenna?
Sent from my SM-G920V using Tapatalk
No, it doesn't produce any wind noise...
I think it was Scosche...it comes with a new base/antenna wire, etc. but all you use is the mast. Remove existing mast and replace with this one.
spencer1122
Toronto, Ontario, Canada
2017 Sport
i got mine from the dealership when i got my truck. this is my second ram that ive used this antenna for and i have no issues. antenna height is 9", was around 40$ canadian.
KAKA
