Skyjacker rear leaf spring lift
dodge truck
Hello,
For my 1500 I am about to purchase the skyjacker DR56S lift springs My plan is to remove the 4" block, raise the rear 2" with just using the spring.
Do I need a block to sit on top of the rear axle to locate the leaf spring?
Has anyone installed a 2 degree pinion wedge shim for u-joint angle?
Thanks
dodge truck
dodge truck
Ok Spring fits into the spring perch.
Have to see about pinion angle. I don't want the pinion pointing downwards.
sublime2300
