rzr6-4
- Jan 25, 2022
- 1,219
- 2,369
- Location
- nebraska
- '09 2500
- 5.7 hemi
I'm toying with the idea of getting some new carli leaf springs but I'm not totally sure with the payload figures. Figured I would get some more input.
On the website they say that the soft ride springs reduce you to "light 3/4 ton capacity". I read elsewhere that one user estimates a 15% reduction. I only tow/haul half a dozen times a year, but when I do I'm pretty much at capacity. I don't have to tow super far so the biggest issue with the payload is that my headlights are pointed at the sky. At face value, these would look like a negative, however.....
When I did my Eibach level, the front actually ended up about 1" higher than the rear. I'm not sure if that's because my factory leafs are old and tired or if the level just provided more lift than anticipated, but I am technically squatted. That said, the new Carli springs give 1" of lift over factory, which may be even more for me if my old ones are sagging. You guys think I would end up with the same amount of rake when loaded, which is borderline but acceptable, or would you suspect it would be worse? Softer springs + taller initial height = same loaded height?
They do also have a heavy duty version which is made for people who always have 1500lb payload minimum, but I suspect that I would end up with little ride quality improvement when unloaded vs where I am now, and that is my whole point for doing this.
