Speedometer calibration
Lake Bum
Gillespie, IL.
I recently went up to a 35” tire and not only is my speedometer off by 3 mph, but the truck often does not want to go into 8th gear. My question is on my 2018 Ram 1500, what’s my options for speedometer calibration? Thanks in advance!
CincyZach
Cincinnati
Some dealer's will change it for you. Of course they will charge you for it.
JB1
Houston, Texas
VF_Mike
Did not know that about dealers. I either used a tuner to change or the shop that did the install would calibrate.
Sent from my SM-G965U using Tapatalk
CincyZach
Cincinnati
Thought I would mention it in case someone didn't want to do it themselves.
VF_Mike
Thanks for that. Good info.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Ditto on the Rough Country, I need one now to fix mine . I used one on my 2015, took like 5-10 minutes, plus it can read codes.
Lifted2wd
On my 35's and 37's I never had issues going into 8th. Do you have a CEL on or ECO disabled.
rwhjr
maryland
Yeah I’ve got 3.21 with 35s and it’ll have no problem going into 8th at a reasonable speed. I guess it’s truck by truck but I’m always surprised/confused when anyone says 35s have prevented shifting into 8th......
CincyCuda68
Ohio
Alfa odb is a better value than a speedo corrector or a tuner (if you have a gasser)
H1Chester
I am going to a smaller diameter, and fatter tire. From stock 275/60R20 to 305/40R22.
I will ask the dealer if they can do it before shelling out for one of these. Dealer will probably still be cheaper...
WTM75
Upstate NY
3.6 Pentastar
I used AlphaOBD. Pretty easy, just follow the directions in the thread in the DIY section.
Goodie1990
