Tape on door coming off
KrisIL
Anyone have this happening? It looks like it's a tape that can be replaced. Will this cause any problems like rust?
Simpleman
New jersey
The black vinyl looks like crap & peels off after a while im thinking of taking mine off or installing putco black platinum pillar posts
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
Mine is an 09 and I cannot get that crap off. Heat gun helps but the glue is years old. Any other suggestions?
NJMOPAR
Older and faster
ELizabeth, NJ
Maybe a 3M rubber eraser wheel?
I know they're recommended for adhesive removal after de-badging.
My 2010 came off with some effort & a Harbor Freight heat gun, I had to get it hot enough to soften & needed gloves to grab & tear it.
bdc2
Ks.
Maybe a wallpaper steamer. Rented one to take interior window tinting off. If you get a layer of steam trapped under it working slowly from the bottom up it takes it right off, adhesive and all.
bdc2
Ks.
Try bug and tar remover for any of the glue that gets left on.
K
KrisIL
I know my wife uses goo gone to remove glue from new windows after they take off the plastic
Sent from my SM-G973U using Tapatalk
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
I've had good luck with goo gone also.
Sent from my SM-T350 using Tapatalk
Simpleman
New jersey
Mine is an 09 and I cannot get that crap off. Heat gun helps but the glue is years old. Any other suggestions? There is a decal eraser you put on a drill and wd40 works great for removing the glue also thats how i did my last ram hope this helps
daveray9
Goo gone isnt to kind to the paint... at least wasnt on mine.
+1 for the eraser wheel, works like a charm
lowufo
Kamloops, BC
2017 Sport
I let my truck sit in the sun on a hot day and it came right off super easy.
Purplert
Yep remove it or buy a roll of 3m stain black or matte vinyl and wrap it
rcmedic
Las Cruces, NM
6.7L I6 Cummins Turbo Diesel Engine
Glad to see these posts s mine has been peeling off a bit for a long while. Now that I know, it's coming off.
Zigi
Port coquitlam
Eco diesel
I had that problem with my 2015 and the dealer said that was normal and that they would put another one on under warranty. I told them to just take them off and call it a day but they told me that they had to replace in order to be under warranty. After showing them the stupidity of their ways, they removed and polished and billed Chrysler for the the new ones that were unused.
Under them is the body color finished. Dumb thing to put on there
southalum
