This may have been beat to death, but............
Ghost2013SCC
Who's put LEDs in stock projectors and how's the performance been?
7777xm
Covington, GA
People seem to like the opt7.
I've tried a few brands, including morimoto 2 strokes and not impressed at all.
Sent from my SM-N920T using Tapatalk
quietpeen
2021 TRX
Hellcat
I did just That and it Is soooo much better
VB712
Maxi_built
Va Beach
I have a retroshop HID kit in my factory projectors. Much much better than the stock bulbs.
Ghost2013SCC
Ghost2013SCC
With HIDs can I get everything to fit inside the housing without drilling through the dust cap?
quietpeen
2021 TRX
Hellcat
Yea, I have no holes in my dust caps
David776895
Yep.....:beatdeadhorse5:
Go hid and never look back.
Most of the stores around me won't install HID anymore, so I am still interested in these threads. I haven't purchased mine yet.
Sent from my SM-G935V using Tapatalk
12sportmc
NC
Why pay a shop to install? Your signature says a 14 if that's true they are literally plug and play for your truck
12sportmc
NC
Drop in kit from retro shop
X2 on what he said! This kit is amazing and soooo much better than halogens lol. I went with the 5k 35 watt.
Idaho Falls, ID
I am currently trying to decide if I want LED or HID. Both have their pros and cons.
Has anyone here tried both? What do you like best?
David776895
LED's are plug and play? Any aiming required?
12sportmc
NC
The fog light LEDs are plug and play when you get the CANBUS versions. Headlights will still require adapters. I was referring to the Drop In HID Kit from retroshop. For the 09-14 models they are plug and play with the supplied CANBUS adapters from the kit. Hope this helps
Oh and yes I did have to re aim the lights but that's is super easy and took 5 minutes. 7mm hex head through the fender.
xrsman
Ontario
3.0 Ecodiesel
The LED system is much smaller than HID. You can fit both the LED high and low inside the projector housing.
I went with LED fogs and highs, with HID low beams. I had a ton of issues with the HIDS. I was sent another resistor box to plug in, and I think that has fixed it..knock on wood.
Sent from my SM-G930W8 using Tapatalk
SSGart
