tire size for a leveled 2wd
cody0707
4.7L
I am leveling my 2wd with a 2" spacer lift. I will be running either a 17" or 18" wheel that will have an offset of -12mm. what tire size would you go with if you had this setup?
quietpeen
2021 TRX
Hellcat
33 or 34" tire is what i would run
WhiteExpress
Midland, TX
Well, they roll a 33" Tire stock. I'm fairly certain you can run a 34" tire stock.
I'd try to squeeze a 35" on there. It'd looks stuffed like a SCORE truck.
Musclemckeester
Houston, TX
n/a
n/a
You could ft 35s without any problems but I would probably stay with a 34" tire.
ramin44s
4.7 v8
I have a 7" lift on 35s and rub some it's all about backspace and offset
