Towing 27' travel trailer....coil bags?
Boots
Sudbury, Ontario
2013 Big Horn
Previous setup....2001 ram, 2x4, with timbren blocks. Hook up to trailer, major ass end sag. But then with properly adjusted torsion bars, truck and trailer all leveled out, looks good, hauls good, no problem!
Now....just got a 2013 big horn, bils @2.1, and pretty agressive m&s tires. Truck is level, looks awesome and rides great. No mods on rear. Am i going to have some trouble now pulling my trailer? Even with properly adjusted hitch and bars? Why? Whats the best fix/mod?
Thx all, you guys rock! (And gals?)
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I am going to install Tuftruck HD coils on mine, some guys like air bags or lift bags.
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
being that you're level you may have some squat. You could always hook up and see then invest in bags afterwards. If the trailer is all you're putting on the bumper bags will be fine. Add air as needed. Easy install
Hemi003
Food for thought, i put firestone airbags in the rear prior to picking up my fifth wheel along with a wireless 1 onboard compressor. I also bought a leveling kit but held off on installing it until i got the weight on. Glad I did. The rear sits high factory stock and squats just enough to use some air to level out. Needless to say, im not leveling it out. I have a good solid ride as is and ill take it. Picture is with 5lbs air, reccomended bump stop.
Arctic-Rodz
RGV, TX
6.7L Cummins
I agree with Hemi003,
When I had my 2013 1500 Sport, I leveled it. Yes I could've gone with airbags to bring up the ride, but because the suspension was so soft, it would squat with anything in the bed.
My 2014 2500 is stock and I tow quite a bit. Stock height for towing is the way to go. More room to play with, air bags will help for the heavy loads. Which is my next move.
Or instead of airbags, I may just go with a dually :D
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Nice setup and welcome to RF.
