Trans problems...shocker!
jordanq10
So I just rebuilt my rear end on my 02 Dodge Ram 5.9 but now that I'm driving it my pedal is normal till about half way then it feels like it hits a wall. But if you push through it the trans will stop shifting till about 2500 to 3000 rpms uv changed my rear dif sensor and the speed sensor in the trans on the bottom. Nothing is binding on the pedals and I'm at a loss for what else it could be. Any help will be appreciated thanks guys
J
jordanq10
No codes other then the p0455
J
jordanq10
Just a update the throttle spring under the truck was seized up some wd40 and she was good to go
joshhhh
