Truck Industry History Question
Sasquatchtdg
Moncks Corner, SC
Given the popularity of "leveling kits" for late model trucks, at what point in the industry did the factory rake become so pronounced across the market for 4x4 trucks? Was it the eco craze that started it? Or maybe IFS becoming the norm? I can't picture engineers willingly agreeing to an off road focused truck with LESS ground clearance.
Just my curiosity for the day.
Sasquatchtdg
Sasquatchtdg
Moncks Corner, SC
I understand that setup, doubt that's 4x4 though. That's what my query was aimed at, 4x4 trucks.
Rav3ncroft
Indiana
Since they come from the factory with a rake then it was certainly designed by the engineers. The rake is so the truck will look level with a full payload. Otherwise it would be dragging @$$.
ShortRAM
Oklahoma
'67 goat got about 12 mpg. '70 goat got 13 mpg. Maybe jacking it up with air shocks wasn't as effective as the way they do it now. Actually, air shocks sound like a good idea to me, but I don't think anybody makes them any more.
JOsworth
Akron, Ohio
3.6 V6
It is simply a result of suspension engineering. Early 4x4 trucks were very simple, unrefined, machines that rode terribly as passenger vehicles.
That is the big rub. Trucks now are truly all around daily use vehicles not farm implements. Back even in the 80's when trucks really started to come into their own as comfortable all around vehicles, 4x4 was not the most common... 2wd was.
Now, trucks need to ride good and stable.. yet customers also expect them to be able to haul and tow. So, when loaded or towing it still needs to ride smooth and handle properly at speeds old trucks only dreamed of. Remember the days of passing a C10 Chevy loaded going 45 or 50??? All that engineering means that when unloaded, the rear suspension will sit slightly higher. I am actually impressed that the rake isn't more pronounced. I love the way my truck rides and drives.... and I used to not like a truck ride for daily use... As long as I can afford to drive one, I will have a truck from here on out.
RLJ10X
Southern Indiana
In 1994 Dodge changed pick ups forever. The next 2 years Ford and Chevy were trying to play catch up.
My truck still has some rake to it. Bilsteins are your friend. Some guys go too far trying to level it. Trucks with their nose in the air look goofy.
air bags are cheap and effective ways to keep your truck level with a load.
Docwagon1776
Midwest
Few trucks are actually focused on off road capability, though, even if they are 4x4. I doubt many buyers actually care, either, as the number who are going to take their truck on trails requiring decent ground clearance (and do so unmodified) is minimal. I'd say like "count the percentage on one hand" sort of minimal, but I don't know.
I think the rake is more so your headlights aren't searching for German bombers once you have a load on the truck...
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Yeah, I had the squirrel lights with my 1500 and my contractor trailer. Some were telling me to add air bags, etc., but then - why are there 2500's? So I bought a 2500 and lived happily ever after........
-B-
Northshore of Boston
pronounced on 4th get , minor on 3rd almost none 2nd , it is not about suspension it is about fuel economy
Docwagon1776
Midwest
How does rake help fuel economy?
Docwagon1776
Midwest
Aerodynamics, drag coefficient, etc.
Rake increases aerodynamics? Drag coefficient? How? Why don't economy cars have rake, then, when manufacturers are trying to squeeze every bit of mileage for CAFE standards as they can?
A lower overall vehicle will have less dirty air flow. Rake slightly increases dirty airflow. An empty truck would be more fuel efficient with a lower overall height and/or no rake.
If you mean when loaded to prevent negative rake, that's closer to the truth but not the reason. Handling and safety when loaded are the reason for rake, while allowing for a much softer ride when unloaded.
Rav3ncroft
Indiana
It's not a conspiracy theory. It simply allows the truck to be level with a full payload. Stop trying to read too much into the design.
It also allows water beads to roll off the hood yet your bed holds water. [emoji23][emoji1787][emoji23][emoji1787][emoji23]
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
Bed shouldn't hold water if you keep the drain holes clean
Sent from my Pixel 5 using Tapatalk
Lowrider357
