Turn Signals not working..
Larmo
Buffalo
06 Ram 1500 5.7...everything has been working fine, today went to make a left turn and got the hyperflash, thinking it was a bad bulb I pulled over(was in a parking lot anyways) and checked bulb. Bulb was good, decided to turn the right turn signal on, same thing hyperflash, so I have no turn signals front or rear, I also have no hazard lights, front headlights work, both high and low beam, fog lights work parking lights work, and brake lights work. I also do hear the audible click when the turn signals a re on, fuses under hood good also...what should I be looking for next..I noticed there's no external easy to find flash relay, could it be the signal unit in the steering column that's going bad..?
McBroom
Denison Tx
Hemi 6.4L
Did you start a 2nd thread on this? I replied to the other thread.
The Blue Mule
Larmo
Larmo
Buffalo
The Blue Mule
It was deleted for some reason.. I did get your message, on the 06 rams is it possible to just replace the relay, doesn't seem like it is. I do hear the clicking sound and the arrows to light up on dash, just no exterior lights will light..front or rear..I already replaced the multifunction switch in steering column also..no luck..worth mentioning, the trailer light turn signals do work..so that harness is working as it should..could this be a tipm issue..
RamDiver
Marlborough, Ontario Canada
2021 DS
OK, so how do I find the thread you DID answer?
Both these members have not been seen for years.
Click on the members name.
On the new window that opens, click on the number below posts.
A new page will open showing details & links to all of their posts.
I looked for 'the other post' about the turn signals and couldn't find it. Maybe you will have better luck.
Or, you could add all the details for the issue you're experiencing and see if you receive replies. :cool:
Arturo Rojas
