Upgrade Your Towing Experience with Weigh Safe and Get a Free Gift
carid
Cranbury, NJ
Hemi 6.1
When it comes to safe towing, understanding your basic needs is essential. Whether you're towing different trailers with varying coupler heights or simply looking to enhance your towing experience, Weigh Safe® ball mounts are worth considering.
In this post, we’ll highlight the top three adjustable ball mount applications from Weigh Safe, designed to improve trailer stability, provide the perfect towing balance, and offer real-time tongue weight readings at a glance—thanks to the industry’s first built-in scale. Weigh Safe’s premium-grade Class 4 and Class 5 adjustable ball mounts are crafted from lightweight, aircraft-grade aluminum, ensuring exceptional durability and a 100% corrosion-free finish over time.
Weigh Safe ball mounts have become a must-have for safe, hassle-free towing. With a wide range of sizes, drop/rise options, classes, and ball sizes—plus essential pins and clips—Weigh Safe has the perfect fit for both lifted and non-lifted trucks.
Weigh Safe® - Class 5 Adjustable Ball Mount with Built-in Scale for 2-1/2" Receivers
Engineered for heavy-duty towing, this powerhouse supports up to 18,500 lbs, delivering unmatched strength and precision.
Specifications:
  • Gross Trailer Weight(GTW): 8000 lb and 18500 lb
  • Receiver Tube Size: 2-1/2"
  • Diameter Balls: 2" and 2-5/16"
Weigh Safe® - Class 4 180 Hitch Adjustable Dual Ball Mount for 2" Receivers
A perfect blend of versatility and durability, handling up to 12,500 lbs GTW for reliable, all-purpose towing.
Specifications:
  • Gross Trailer Weight(GTW): 8000 lb and 12500 lb
  • Receiver Tube Size: 2"
Weigh Safe® - Class 5 Adjustable Ball Mount with Built-in Scale for 3" Receivers
Built for extreme towing demands, this heavy-duty hitch supports up to 21,000 lbs, making it the ultimate choice for serious haulers.
Specifications:
  • Gross Trailer Weight(GTW): 8000 lb and 21000 lb
  • Receiver Tube Size: 3"
Bad news: Not all hitch balls are the same—each size is designed to meet specific towing needs.
Good news: Weigh Safe has you covered. Explore our extensive selection of Weigh Safe® ball mounts, designed to work seamlessly with different load weights and trailer types. Find your perfect setup today at CARiD!
carid
carid
Cranbury, NJ
Hemi 6.1
Take Advantage of our Exclusive Offer!
Whether you're towing a heavy-duty trailer, a loaded car hauler, or a work rig, one thing is certain: tongue weight matters. That’s where Weigh Safe revolutionizes towing safety.
Now for the exciting part! Purchase any of the Weigh Safe Adjustable Ball Mounts with Built-in Scales mentioned above, and you’ll receive a FREE product of your choice from the options below:
  • Trailer Coupler
  • Ball Lock
  • Hitch Storage Case (WS23) & 3-Piece Lock Set
Don’t miss your chance to create the ultimate towing setup—adjust your trailer height in seconds and get a FREE bonus with your purchase!
Fatboy1989
