Want wider tires without rubbing
Joseph DeNapoli
New York
Hemi 5.7 V8
Hi everyone. I'm driving a 2017 Ram 1500. I'm looking to put bigger tires on my stock ram. I originally wanted to go with 33"x12.5"x17" but everyone is saying that you get some rubbing depending on how wide you go. I bought 17"x9" rims with a -12 offset. How wide can I go without having to deal with any rubbing?
Thank you
tron67j
Maryland
Well, if everyone is saying it won't work ..
Your best bet is to work with a tire company at their facility. While someone can give you a theoretical solution, and you will probably get a few, your best bet is to actually have each fender well inspected to make sure the final set of shoes actually will fit. And if they mis-measure it is on them to fix. If you order the wrong size and find an installer, you are out mounting, balancing, removal, and shipping plus restock fees.
brianw0048
EcoDiesel
You can search wheel/tire sizes on customwheeloffsets gallery.
ThunderMug95
North Prince George, VA
Thank you
Those wheels/tires should be fine if your leveled. I ran 20x9 0 offset with 305/55. I had a slight rub at full lock on the front swaybar.
-12 should give you plenty of clearance off that and clearance from your UCA’s.
southalum
