went to the track last night
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
pretty proud of my time. only made 2 runs. still having a little belt slip issues on the s/c. as soon as i get that figured shoud be in the 13's. and thats what i have been shooting for. this is full street trim. nothing removed and running on 35/12.50/17 cepek crushers. sorry no pics son didnt grab camera like i asked and i didnt check.this was the better of the 2 runs i made.
r/t- .026
60'- 2.215
330- 5.940
1/8- 9.097
mph-78.49
1000- 11.778
1/4-14.046
mph- 99.80
ramin44s
4.7 v8
not bad for 35s especially
Okiespaniel
Work, Shop, Computer
magnum, 5.9
That's imnpressive since you did this with mud tires...LMAO !
You oughta get something that hooks up...or is this with an open rear? Because your 60' sucks!
If you can get the 60' time into the 1.6 range you'll be in the 13's for sure.
BTW, what do you think your truck weighs?
My handy dandy caculator based on an estimated weight of 5400 lbs says you should be running 13.65's...so yeah, lack of traction.
T
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
open diff. 3.92's. i have the powertrax no slip in the garage, gonna get that in this winter.
i have street tires on the durango rims but i really wasnt planning on running. son talked me into it. that was with him in the pass side too. hes a extra 200lbs. lol
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Strong work, thats very good times for the first time out.
Okiespaniel
magnum, 5.9
The powertrax alone might be worth .5 just for the hookup.
BTW my "pocket dyno" says 419 hp...Sweet!
T
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
i weighed it before but now i cannt remember. it was more then 5400. i have spray in bedliner and rockers, gorhino 3step side steps too. and those cepek crushers are very heavy tires. i need to weigh it again.
T
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
gonna get that 2 more lbs of boost this winter that i have been looking for too. so be ready to bump that 419 up a little.lol
T
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
i would say my 60' times arent super great because my boosties arent fully kickin yet.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
How were the temps looking after the passes? Your ET and 60' will imporove the more pass's you can make with it. These are almost shake down passes.
Okiespaniel
magnum, 5.9
I'd say one wheel squeal.
My suspension guy used to tell me "for every second of tire spin, there's a tenth of a second to cost you a win".
T
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
my temps were climbing. the engine was close to 200. but thats something else i am working on right now. running the black magic 180 efan now. temps were always low until i installed the s/c. now they climb close to 200. but i have 2 12" fans, sheetmetal, wiring harness,relay,rubber seal for the shroud i build. 180fan is 3300cfm, the new fans are 2300cfm each. should help a good bit. my intercooler blocks my rad a bit. so its not really getting the air it should. i prolly would have it all fabbed by now but i didnt know what i was gonna do with the washer bottle. i didnt want any lights on in the dash. i have a nice stainless overflow tank for the rad too.both fasten to the factory shroud. but i think i got it figured, maybe. just sent the money out for a moes washer tank for the hemi trucks. it has 2 holes for the sensors. so i will just have to wait and see when it gets here. may have wasted 75$ on it. but its worth the chance.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The S/C's just build heat in general. Even with the low temp T'stats and coolers we run they can still get high.
T
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
i am running a highflow water pump and 180stat too. i have tried 3 different stats hoping that would make a difference for a easy fix, but that was a no go. thought about trying it out with no stat and see what happens. but everything i have done i have made sure there is no lights on in the dash. and i have a feeling if i ran a 160* stat or no stat check engine light would come on. and that is a big peev of mine, check engine lights.
and if the new efan setup i fab doesnt work, gonna have a big ass radiator made.
Catchin Zs
Wilmington, NC
Pretty good times with 35's, sounds like fun. So what cooling system will you be running next since the one you have now is ineffective?
T
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
its really not ineffective. it will run all day long without issues. cruizin and such. 200* is the most i have ever seen it get. and thats hammering on it hard a few times. and on a 90*+ day. and if you stop hammering on it it cools right back down. i just want it to run a consistant temp at all times. even when running it hard. around like 180*. its 40miles just to get to the track. and it never got even close to half on the temps.
T
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
and if i cannt get it down to the temps i like, just gonna go to a local radiator shop and have them build me a new bigger radiator.
ameer73
