What are the largest tires I can put on the factory 17" rims?
Farmer17
Edmond, OK
V6
I have a 2018 Quadcab Tradesman 2WD 1500 V6 and have about 45K miles on the factory 17" Goodyear SRAs and I will be needing tires in about 5K more miles. I have had great luck with the factory tires so far except in the mud so I'm wanting a little more aggressive tire but I would also like it slightly taller if possible just because I think it would look better. The existing tires are 265 x 70R x 17 so is there a bigger tire I can put on without getting the truck lifted?
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
I hate to say it, but you're pretty close to (safely!) maxed-out on tire size for those rims. If you want bigger, there's a couple of things you have to start thinking about...
1) Bigger tires start getting you into clearance issues up front even if by some miracle you do manage to stuff a bigger tire on what you have. People get around that either by leveling (lifting the front with a set of specialized struts), or getting rims that have a very large offset (dished-out), or just biting the bullet and lifting the whole truck. That middle option means you may as well just get bigger rims anyway.
2) Safety. If you have these big vulcanized balloons stuffed onto these skinny little stock wheels, the chances of a bead separation event go way up. You can go up a little, but honestly? I wouldn't recommend it.
3) You and I share one thing in common: The itty-bitty 3.6L v6. Bigger meats means lower mpg. If you're okay with that, okay, but you will notice it a lot sooner than our Hemi/diesel-driving brethren will. Fun thing I noticed recently - switching from stock Goodyear SRAs to Falken Wildpeak AT3's with a very aggressive tread managed to knock around 3 mpg off my fuel efficiency average according to the lie-o-meter... and I stuck with the same stock tire size. Now if you get bigger meats with an aggressive tread, err, yeah... expect to lose a lot of mpg.
ram150082
