What is the largest tire I can put on my 17" X 8" Aluminum wheels?
dkunesch
Aberdeen, MD
Cummins Turbo Diesel
I am looking to get the largest tire on my rims without rubbing. I looked at some 35 X 12.5 LT's
mrack
If your truck is stock, 285/70r17. Most 12.5s will rub on stock offset.
diymirage
Banned
the widest tire reccomended for an 8 inch wide rim is 245, which is less then 10 inches
you can fit a 12.5 tire on it, but the recommended minimum is 8.5
but, not my monkeys
D
dkunesch
Aberdeen, MD
but, not my monkeys
Originally I was going with Faulken AT4's 255 /80 R17
Dean2
Near Edmonton
Why ask if you already decided. Fit them and see if everyone else is wrong! Let us know how it works out.
EVERY DAY I LOVE NEWBIES MORE AND MORE.
mrack
How wide you can go on a 8” wheel is completely dependent on the size of the tire. The more sidewall, the wider the range of wheel widths will be. There’s no one size fits all answer.
285/70r17 (about 11.5” wide) are listed as good for 7.5-9” wide wheels.
mrack
255/80r17 are actually narrower then stock (265/70r17 is the stock size) so that argument is void anyways. And at 33” tall you should have no clearance issues at all.
olyelr
Kewadin MI
but, not my monkeys
Huh? Power wagons come from the factory with 285’s and 8” wide wheels.
I have ran 12.5” wide tires on 7-8” wide wheels many many times over the years. Never once had and issue.
KingJ2
Calgary
Can you fit 17" wheels on the 5th gen Ram?
I have read many times that 18' is the smallest wheel available regarding the brake calliper limitation.
bbramer0820
