wheels and tires
marcsnyder
No where
ok I know i"m :beatdeadhorse5: but I just want to make sure that I have my facts straight. I've got a 2013 1500 crew cab express and I want to put XD series rockstars 17", -12mm offset, and 4.52" backspacing, 35/12.5/17 nitto trail grapplers, and bilstein 5100 shocks set at the max. This will work with only minor rubbing at full lock and dips right?
link for the rims on tirerack
http://www.tirerack.com/wheels/Whee...lse&filterNew=All&filterWeight=All&sort=Brand
mattman_13
I assume you will be good. These trucks have a huge fender well and your main concern with size is width. That offset should easily clear the upper control arm. Most likely rub the sway bar at full lock.
A member on here ran close to that set up before his body lift. Look for his build thread "glocknram". I also believe he had to do some fender well trimming.
marcsnyder
marcsnyder
No where
sweet I don't mind doing some trimming i had to do alittle on my 07 dakota to fit the 275/60/18 BFGs ATKOs i had. I might pull the front sway bar I pulled it on my dakota and didn't really notice a difference.
Steve58
