Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Most any tractor or speed shop can make those hoses. They may even be able to clean and reuse the same ends. I'd call around to places that work on tractors.
As mentioned above try a Local tractor shop ! Many Auto parts stores that also make Hydraulic lines may be able to make your fuel lines! Also There are tons of options on Google !
these hoses have the plastic or nylon on the inside. Where they connect to the metal lines there isnt a clamp or anything, almost looks like heat shrink.
i can see why hardly anyone has responded. yall wanted to save me from soul crushing disappointment realizing that there isnt another fuel pump module on this planet. Could I not just swap to like a '91 tank?
You can find the fitting at pep boys autozone etc. You may have to run new hose and clamp or use a synflex hose setup. A hydraulic shop may be able to make it a well
